Mac OS X 10.1 Tier 2 languages components - Available now!
Raytse
文章: 18
註冊時間: 10/02/2001 1:01 am
來自: Hong Kong
#1 文章 Raytse »
Please note that the Tier 2 Mac OS X 10.1 language components has
been posted in the Software Update today. This covers Traditional
Chinese, Simplified Chinese, and Korean. You now can update your
Mac OS X 10.1 and will have access to Traditional & Simplified Chinese,
Korean, English, Japanese, and other European languages all unified
under Mac OS X 10.1.
If you have already installed Mac OS X 10.1, just go to the System
Preference & launch Software update and click 'Update Now', the tier 2
language components will appear & you can install the ones that you
like.
This is convenient for those who computes predominately in an English
environment but occasionally need to access other languages
capability, for e.g. in Hong Kong many computes in English but has a
occasionally need for both Simplified and Traditional Chinese. For
customer that would prefer to compute under a specific language other
than English, e.g. in China this would be Simplified Chinese, customer
would use the Simplified Chinese Mac OS X 10.1 which also comes
with the Mac OS 9.2.1 Simplified Chinese.
This is only available on Mac OS X 10 version 10.1.
Arthur
文章: 379
來自: .tw
#2 文章 Arthur »
<BLOCKQUOTE><font size="1" face="XYZ">quote:</font><HR>原始發信人 Raytse:
<STRONG>This is convenient for those who computes predominately in an English
This is only available on Mac OS X 10 version 10.1.</STRONG><HR></BLOCKQUOTE>
So, I cannot use it often or it is not good to use often. [img]images/smiles/icon_biggrin.gif[/img]
tz
文章: 66
#3 文章 tz »
最後由 tz 於 12/20/2006 8:56 pm 編輯,總共編輯了 1 次。
Raytse
文章: 18
來自: Hong Kong
#4 文章 Raytse »
It's the message I got from the email of Apple Hong Kong today......I've tried to update it through software update, but I can't get it too.....
oeyvind
文章: 1990
註冊時間: 10/03/2001 1:01 am
來自: 大馬/星洲
#5 文章 oeyvind »
<STRONG>It's the message I got from the email of Apple Hong Kong today......I've tried to update it through software update, but I can't get it too.....</STRONG><HR></BLOCKQUOTE>
Patience young grasshopper! I posted HERE yesterday as I learned that from a pal within Apple... he updated his machine early last morning in Singapore...^^
[ 10-18-2001: 留言編輯者: oeyvind ]
the real unknown
冰果室打手
文章: 2610
來自: GMT-5
#6 文章 the real unknown »
蘋果員工連上的Software Update Server和我們外人用的不一樣。
digdog
文章: 1297
#7 文章 digdog »
<BLOCKQUOTE><font size="1" face="XYZ">code
<pre>http://swscan.apple.com/scanningpoints/scanningpointX.xml</pre>
這個 xml 檔的內容也很有趣啦,大家可以瞎著眼隨便看。
結論:我們應該想辦法把 URL 設到星加坡的機器上才對…
[ 10-19-2001: 留言編輯者: digdog ]
the real unknown
冰果室打手
文章: 2610
來自: GMT-5
#8 文章 the real unknown »
蘋果內部用的Software Update也是用一樣的URL。只是在蘋果的IntraNet上那個server的DNS是指到內部(在防火牆裡面)的主機。
結論:不必亂指了。發揮Mac使用者特有的耐性,乖乖等吧。
kulong
文章: 62
註冊時間: 05/05/2001 1:01 am
來自: U.S.A./Houston
#9 文章 kulong »
有點兒失望。 [img]images/smiles/icon_sad.gif[/img]
