在OS X下打的中文檔名,在OS 9下卻是亂碼,反之亦然。
請問這是什麼原因?Unicode嗎?有什麼解決方法呢?
謝謝。
OSX與OS9的中文
OSX與OS9的中文
<BLOCKQUOTE><font size="1" face="XYZ">quote:</font><HR>原始發信人 derekyu:
<STRONG>在OS X下打的中文檔名,在OS 9下卻是亂碼,反之亦然。
謝謝。</STRONG><HR></BLOCKQUOTE>
yup, it's in Unicode... if u have DiskWarrior or NU, make sure you DO NOT use them to fix files/folders name in Mac OS X, or you'll loose the CJK text.
OSX與OS9的中文
Then, if you don't mind, how to solve the problem when viewing a chinese-named document in a server of OS 9 from the side of OS X? Or vice versa? Is it a dead end? Somehow I could view my old OS 9 documents fine within the same hard disk where reside OS X and OS 9.
Thanks.
Thanks.
OSX與OS9的中文
<STRONG>Then, if you don't mind, how to solve the problem when viewing a chinese-named document in a server of OS 9 from the side of OS X? Or vice versa? Is it a dead end? Somehow I could view my old OS 9 documents fine within the same hard disk where reside OS X and OS 9.
Thanks.</STRONG><HR></BLOCKQUOTE>
對不起,這一點我不能幫您。I don't use Classic Mac OS anymore these days (except for Photoshop in Classic) and I don't do much CJK(中日韓)text processing also...^^
[ 11-26-2001: 留言編輯者: oeyvind ]
- the real unknown
- 冰果室打手
- 文章: 2610
- 來自: GMT-5
OSX與OS9的中文
這個問題是無解。除非等萬能無敵聖明大蘋果把 OS X Finder 教會在檔案命名的時候不要把 textEncodingHint 一視同仁的設成 kTextEncodingMacRoman。
OSX與OS9的中文
在mount碟時,它會問你是什麼Encoding的,我就是如此用OS Xmount我在OS 9機上的share drive。 [img]images/smiles/icon_biggrin.gif[/img] [img]images/smiles/icon_biggrin.gif[/img] [img]images/smiles/icon_biggrin.gif[/img]
不過如果上面有那encoding所不容許的字,如用繁體中文mount但有日文字,那些file是會不見了! [img]images/smiles/icon_eek.gif[/img] [img]images/smiles/icon_eek.gif[/img] [img]images/smiles/icon_eek.gif[/img]
