DVI TO ADC Adapter!!!!Help!!!
jeffapple
文章: 13
註冊時間: 12/19/2002 1:01 am
來自: hk
#1 文章 jeffapple »
I new buy 15" Studio display (LCD) -------ADC interface and
Apple Dvi to Adc Adapter .
I use G4/400 (AGP) long times ,
Display Card is "Ati Range 128 Pro"-------Dvi ana VGA Port.
But I can't use it ........
when switch on machine . listened "dong" , the LCD have white colour display on desktop , about 2 second , the desktop was disappeared but the LCD display's power light still on .....I try reset PR-Ram,
reset logic board, replace another display card (same model),
disconnect HD to boot up , also same problem on Display!!!!
I'm sure 15" LCD display , Apple DVI to ADC Adapter and display card
is work!!!!!! Because I stand alone try that.
Please help me !?!?
thanks to replyer...... :oops:
