Bluetooth after startup?
Is there anyway to make Mac OS X see that there's Bluetooth when the BT USB adapter is plugged in only after startup?
Re: Bluetooth after startup?
Try this:oeyvind 寫:Is there anyway to make Mac OS X see that there's Bluetooth when the BT USB adapter is plugged in only after startup?
After startup, open up terminal and type:
sudo kextunload /System/Library/Extensions/IOBluetoothHIDDriver.kext
After plugging the module, type:
sudo kextload /System/Library/Extensions/IOBluetoothHIDDriver.kext
