昨天心血來潮 把埃麥克拆下來剖肚
原本以為會有兩個插槽 想不到跟小白一樣只有一個筆記型的RAM擦曹 請問傳說中的另一個在哪裡呢??
THANK YOU LAR~
新的iMac只能再加裝一條筆電的RAM嗎?
Koala Bear
- 文章: 11
- 註冊時間: 04/09/2002 1:01 am
- 來自: Hong Kong
After U open the base U can see the so-dimm slot and u also can see few star shape screw around the base, use a star shape screw drive to open you will see the DIMM slot beside the CPU.
P.S. After u open it your Mac will be out of Warranty, please think before u do. That DIMM slot will accept most PC-100 and PC-133 not over 512mb.
P.S.S. I have install a Kingston 512mb PC-133 DIMM by myself as well [img]images/smiles/icon_wink.gif[/img]
hi 樓上的大哥
試只要拆掉底座銀色的殼就 Out of Warranty?
還是說要拆到裡面?
那不就太奇怪了 自己裝也不行
還是說要拆到裡面?
那不就太奇怪了 自己裝也不行
需再拆一層,裡面會再有一條168pin的記憶體 [img]images/smiles/icon_biggrin.gif[/img]
謝謝 Ming ,
但是拆了就沒保固 那誰要拆..??
蘋果的設計有點矛盾..........
但是拆了就沒保固 那誰要拆..??
蘋果的設計有點矛盾..........
Koala Bear
- 文章: 11
- 來自: Hong Kong
Apple Have say it was Factory install only
