各位老手~請教I POD 與歌詞
點點點
文章: 9
註冊時間: 09/20/2004 8:22 pm
各位老手~請教I POD 與歌詞
#1 文章 點點點 »
今天拿到我的新I POD 想問問老手怎樣才能邊聽歌邊看歌詞呢~ 怎樣把網站上的歌詞放到我的I TUNE裡~THX~:lol:
點點點
文章: 9
#2 文章 點點點 »
:( 都沒人知道嗎>"<
麻煩大家幫忙一下~感恩捏~
Changhsin
文章: 1279
註冊時間: 01/06/2003 2:55 pm
#3 文章 Changhsin »
答案在這裡,請自行參考:
http://docs.info.apple.com/article.html?artnum=93951
tylerlin
文章: 618
來自: 溫哥華 / 台北
#4 文章 tylerlin »
這個東東讓你在MAC上管理歌詞。我沒用過,不好不要怪我。 :)
當然我假設你用MAC.... 因為這軟體只有MAC版。
Build Your Own Lyrics Collection
KaraTunes puts all your lyrics data in one single database, letting you save, modify, and search lyrics with an easy-to-use interface. With KaraTunes, you don't have to save lyrics as irrelevant text files.
http://www.ideographer.com/karatunes/
iPod Support
You can easily upload lyrics to your iPod as notes. When accessing lyrics on your iPod, press the Select button to listen to the song you are viewing.
Share Lyrics
KaraTunes can export your lyrics library for another computer or sharing lyrics with friends.
Unicode Support
KaraTunes supports the Unicode standard, so you can add songs from almost any language into your lyrics collection.
點點點
文章: 9
#5 文章 點點點 »
感謝各位的幫助~問題解決嚕~感恩捏~^Q^~ :lol:
