Thanks 老殊,
First, Beijing is already a font right?! [img]images/smiles/icon_smile.gif[/img]
Secondly, I had fix the problem La. Well, the method is a little bit dumb but it works.
Anyway, I still can't open any Chinese Exel file by MS Excel 2001 since the file was produced by MS Excel 98. (SC. Beijing). [img]images/smiles/icon_sad.gif[/img]
Well, I try to save the file as Excel 4.0 worksheet format(Not WorkBook). Then, I use the Applework 5.0 & 6.0 to open the file. Yes, it works great and all the setting as the same. Cool. Now, I work all the perious Excel file by Applework. Hope this information can help others or anybody can fix the MS Excel 2001 Chinese problem? Please post it.
Thanks.
Excel 2001 Chinese Problem! Please Help!
I have a Chinese Excel File and all fonts are in Beijing. I can't decode the fonts after the file transfer to Excel 2001. I had already reg. the software in Chinese. What should I do or anything I did wrong? Please help!
Thanks
Thanks
Beijing...is it an simplified Chinese file? Then you'll need SC fonts...
