麥金塔相容的HDTV
tylerlin
文章: 618
來自: 溫哥華 / 台北
麥金塔相容的HDTV
#1 文章 tylerlin »
大家要不要來製作個相容名單?這樣想買Plasma或LCD-TV的朋友可以參考。
例如以下:
"Hitachi SX5500 LCOS projector with my Powerbook G4/800. The DVI output is beautiful and film-like at 1280x1024 -- and delivers better color than the component video coming in from a Panasonic RP82 DVD player."
http://htmug.com/phpBB2/viewtopic.php?t=16
"Panasonic TH-42PHD6UY 42" HDTV connected to my G4 DP 867 with nvidia Geforce4 MX and it works fine at 1024x768 @ 60Hz.Panasonic TH-42PHD6UY 42" HDTV connected to my G4 DP 867 with nvidia Geforce4 MX and it works fine at 1024x768 @ 60Hz. I didn't have to do anything special. I just connect the DVI-I cable on the DVI out of the video card and connected to the Plasma with the option DVI blade card. "
http://htmug.com/phpBB2/viewtopic.php?t=223
"RCA 34" Scenium hd hooked to my G4 using the DVI input. I am using Switres to get 540X960 output from my radeon 8500 mac edition."
http://htmug.com/phpBB2/viewtopic.php?t=232
