版主: ross_tt 、bryanchang 、Faust
文章: 7057 註冊時間: 04/19/2001 1:01 am
由 bryanchang » 12/20/2004 7:04 am
you need to get multi-coated glass for your eye glasses!!!
oeyvind
文章: 1990 註冊時間: 10/03/2001 1:01 am
來自: 大馬/星洲
由 oeyvind » 12/20/2004 8:03 am
bryanchang 寫: you need to get multi-coated glass for your eye glasses!!!
My glasses is multi-coated if not you can't even see my eyes!
文章: 8062 註冊時間: 05/25/2001 1:01 am
由 ross_tt » 12/20/2004 8:12 am
這張照片頗有專業雜誌刊登封面人物的風格。
oeyvind
來自: 大馬/星洲
由 oeyvind » 12/20/2004 8:17 am
Thanks, glad you like it. He's another photographer, actually one of the speakers of the day, got him to take took my pix... ^^
Ricyu
文章: 29 註冊時間: 11/08/2004 9:58 pm
來自: Somewhere around
由 Ricyu » 12/20/2004 8:24 pm
文章: 4120 註冊時間: 01/16/2002 1:01 am
由 Faust » 12/20/2004 10:27 pm
更簡單的方法..把鏡片拿下來就好了..
elitekuo
文章: 37 註冊時間: 04/29/2003 4:18 pm
由 elitekuo » 12/27/2004 5:01 pm
Faust 寫: bryanchang 寫: you need to get multi-coated glass for your eye glasses!!!
更簡單的方法..把鏡片拿下來就好了..
這時可能變成眼睛不自然。
CONTAX rules!
由 ross_tt » 12/27/2004 5:22 pm
elitekuo 寫: Faust 寫: bryanchang 寫: you need to get multi-coated glass for your eye glasses!!!
更簡單的方法..把鏡片拿下來就好了..
這時可能變成眼睛不自然。
並不會這樣。
一般外面的婚紗攝影公司也都是這樣子做。
文章: 5222 註冊時間: 04/26/2001 1:01 am
由 麻辣杯麵 » 12/28/2004 3:43 am
會喔!如果近視很深,把鏡片拿掉眼睛會變得怪怪的~
由 Faust » 12/28/2004 2:07 pm
之前到朋友那裡把玩了一下,效果真是不錯~~不愧是機皇~
Elinchrom真的很好用,價格合理回電又快,缺點是控光附件既貴又少得可憐..
bang504
文章: 1 註冊時間: 01/16/2005 12:40 am
#12
由 bang504 » 01/16/2005 12:46 am
Those shots looks nice. But I can not ignore one thing...
Everyone in your shots seems looking to the same spot and
all lighting diagram are split light.
It's not the matter of eqipment, it's the image bothers me a little.
