any ACROBAT user here?
josephcool
文章: 45
註冊時間: 07/15/2001 1:01 am
來自: Hong Kong
#1 文章 josephcool »
Hello, any ACROBAT user here?? I got a few questions about the software.
1: Is that only Acrobat can EDIT PDF file?
2: Can Acrobat export PDF to MOST of the other major softwares, and import images and texts from (many) different softwares together on a "PIECE" of PDF (not file, a file can have many pages) without having the layout changed?
3: My primary goal is to do homework only available in PDF DIRECTLY (I have to print it out, do it, scan the completed job then send it back through email, u see, how trouble!!) I don't have printer and scanner (My friend help me), would Acrobat 5.0 be a better choice?
4: I would like to store most of my paper works, notes, graphics, etc digitally, would PDF be a good choice-for it's cross-software-platform ability?
THANKS!!!
老殊
文章: 1113
來自: San Cala
#2 文章 老殊 »
我在PC上有跑Acrobat,大概可答覆部份問題。
1. 如你所接收的Acrobat要有password才可更改,則連Acrobat也無能為力。
2. 你的Documents要給人作參考用途嗎? Acrobat可export postscript檔,但export後已不可edit了。
3.假設接收者只是要read,不用更改內文,那send as PDF也無大問題
4.愚見:作為功課,我看不如買個MS Office /AppleWorks還好。
wenchieh
文章: 148
註冊時間: 05/17/2001 1:01 am
來自: Toronto, Ontario
#3 文章 wenchieh »
1. PDF Files經過輸出後,底稿的部份已不可更改,但是可以用類似layer 的方式,加註或是加上其他符號。不知道你所說得edit PDF files是要做到怎麼樣的方式?
2. PDF檔案的製作,主要有兩個方式,第一,在chooser裡選一個Acrobat PDF writer,就好像你選一個列表機一樣,在應用軟體裡,你就直接選取print,把PDF write當作是一個列表機來操作即可,但是輸出時,會已pdf files來取代真正列表機的列印。 另一個方式是我做常用的,就是還是在chooser裡選取任何一個postscript printer. 但是記住,下列印指令的時候,把Destination下的printer改成file,這樣就會有個ps的檔案產生,然後用Acrobat裡的Distill轉成PDF。我之所以選取第二個方式是因為圖形可以維持應該有的解析度,而
josephcool
文章: 45
來自: Hong Kong
#4 文章 josephcool »
ar.......I got the basic concept now. Thanks
okay, let me explan my what I want to do with ACROBAT more in detail.
I'll talk about how I EDIT soon, but at the very beginning, If I don't have Acrobat to export the original PDF, I have to reproduce the text, symbols , everything in the same layout as original before any "EDIT". that load of WORK!!!
I don't have to edit the original layout. let's say the PDF have certain underline areas which expecting anwsers? My "EDIT" is to fillin those area. actually, my homeworks of Maths and Science have so many symbols that I don't know how to type, and I don't want to type, I just want to "WRITE" my answer even with mouse. Is that what MIPS called "LAYER"? whatever, how can I do make it?
PS: again, i don't want to reproduce the original page because of those science symbols,u know
ar..........my teacher have to mark on it, but I think that they send me PDF and I send them PDF back is ................. fair. hahaha
PS: I don't have printer and scanner
thanks!!!!!!!!!
josephcool
文章: 45
來自: Hong Kong
#5 文章 josephcool »
I forgot to state I got Applework for editing
and I copy and paste some text from adobe about Acrobat 5.0, I understand the words, but I don't have any on-hand experience so I'm not sure is that work for me. THANKS again!!!!!!!!!!
from adode:
Save Time by Repurposing Content
Acrobat 5.0 software takes advantage of a more robust Adobe PDF format, enabling you to share not only your electronic documents but the contents of those documents as well.
Save as RTF夎ou can save an Adobe PDF provided by colleagues or obtained from Web research as a Rich Text Format (RTF) file, then easily incorporate text from the RTF file into reports and presentations.
Extract images哻crobat 5.0 lets you enable colleagues to extract images from Adobe PDF documents and save them as TIFF, JPEG, or PNG files. The images can then be incorporated into word processing, presentation, page layout, HTML, and other files. Each exporting format provides additional options for fine-tuning the conversion. When exporting to JPEG, for example, you can determine the compression quality (Minimum, Low, Medium, High, Maximum), resolution (from 72 to 600 dpi), and other settings.
Save as images垹ith Acrobat 5.0, you can quickly convert an Adobe PDF file into images simply by saving to the TIFF, JPEG, or PNG formats. Acrobat converts each page of the Adobe PDF file into a separate image file in the chosen format. Acrobat also lets you save Adobe PDF files as PostScript and Encapsulated PostScript files. Many of these options offer specific export settings for more efficient, reliable file conversion. The PostScript option, for instance, lets you save to PostScript
Language Levels 1, 2, or 3; convert TrueType to Type 1 fonts; select a transparency level; and more.
老殊
文章: 1113
來自: San Cala
#6 文章 老殊 »
If you really need to use PDF to exchange & edit, the assumption is you & your counterpart(S) must have both Acrobat3/4/5.
In my opinion Acrobat is a tool to export final output that someone who need not to obtain the original software, like PageMaker, QXK etc. Instead end-users just download the Reader version for reading. If you need further format change & file import (e.g. pictures),
老殊
文章: 1113
來自: San Cala
#7 文章 老殊 »
For mips:
My feeling is that the engine itself is a bit faster. V.3 is defintely a no-go (well, difficult to get nowadays...) V.4 & 5 are quite similar,
josephcool
文章: 45
來自: Hong Kong
#8 文章 josephcool »
Sorry, may be I didn't state my question clear enough.
1: my homework is only available in PDF
2: I have to FILL my homework on the question sheets (it's like a layer over the original, not answering on another sheet)
3: no 2 question sheets are the same
4: I don't have printer and scanner
5: my school didn't state that they don't accept PDF. (so it's out of question)
6: I will do the editing with any possible software, not just Acrobat!
okay, now I list a new set of questions, all of them are YES/NO question, becasue I really want to solve my problem.
1: I think if I neither buy the scanner-printer set or Acrobat. I can do nothing except reproducing every single question sheet before I really doing my homework. Is that CORRECT?
2: According to adobe's site, I should be able to edit the original text when PDF is changed to Rich Text Format. Is that CORRECT?
3: Or at least, I should be able to export the hole PDF page to image, like JEPG,etc, then DRAW on it. Is that CORRECT?
4: after I have finished my homework, I should be able to convert my final work back to PDF. Is that CORRECT?
I JUST WANT TO DO MY HOMEWORK, I MEAN REALLY ANSWERING THE QUESTION, NOT PREPARE THE QUESTION SHEET, PLEASE HELP ME, THANKS!!!!!!!!
josephcool
文章: 45
來自: Hong Kong
#9 文章 josephcool »
okay, only one request
ACROBAT USER, please tell me can I export a hole PDF file as one image file format like jpg, etc
Thanks!!!!!!!!!!!
老殊
文章: 1113
來自: San Cala
#10 文章 老殊 »
<BLOCKQUOTE><font size="1" face="XYZ">quote:</font><HR>原始發信人 josephcool:
<STRONG>okay, only one request
Thanks!!!!!!!!!!!</STRONG><HR></BLOCKQUOTE>
I have no chance to see your urgent request till now....
Yes, you can export as JPG, TIFF, PNG in v.5
EXPORT>EXTRACT IMAGES AS>JPEG/TIFF/PNG...
josephcool
文章: 45
來自: Hong Kong
#11 文章 josephcool »
really thanks everyone has posted advice here
I've just tried MAC Arcobat at my friend's home
the export function is great
and actually I can do my job just with the basic acrobat tools on panel like pencil, type, etc
I'll buy arcobat for sure, that save my life!!!!!!!
by the way, since English version got the asian languages support, what's the difference between Chinese and English version except the interface language, I'm using English OS, thanks!!!!!!!!!!
