Super drive, worth the money?
Italian Soda
- 文章: 66
- 註冊時間: 02/21/2005 8:52 pm
- 來自: Here
I just need suggestion on whether or not get a powerbook with super drive, I do make DVDs with videos, just not so often, maybe once a while
. Can people tell me about their usage on their super drive? That would be really helpful.
Apple is delicious but expensive, although expensive doesn't stop the real consumer of Apples
- Chao, the good one
- 嗜冰客
- 文章: 1082
- 註冊時間: 08/21/2001 1:01 am
- 來自: Bright Side of the Moon
Re: Super drive, worth the money?
As you suggested, you DO NEED IT...... once a while.Italian Soda 寫: I do make DVDs with videos, just not so often, maybe once a while.
However, I thought I would use SuperDrive to backup files, but I found extra hard disks will make my life easier. I only use SuperDrive for making DVD (video). Well........once a while.
