可以用視訊得聊天軟體
celestino
文章: 13
註冊時間: 03/06/2005 12:00 am
可以用視訊得聊天軟體
#1 文章 celestino »
請問現在有沒有什麼軟體支援視訊的,剛用過proteus好像沒看到這個功能,而且也沒辦法像msn那樣顯示自己的圖片和看別人的圖,請各位大大提供一下,謝謝.........
文章: 8061
#2 文章 ross_tt »
iChat
celestino
文章: 13
可以用視訊得聊天軟體
#3 文章 celestino »
那ichat有支援msn嗎??
文章: 8061
Re: 可以用視訊得聊天軟體
#4 文章 ross_tt »
celestino 寫:那ichat有支援msn嗎??
lynnliu
文章: 26
註冊時間: 03/02/2005 3:48 pm
#5 文章 lynnliu »
Proteus and Adium這兩種軟體都可以支援圖片顯示
可同時使用多種不同帳號,但尚不支援視訊功能
Yahoo可以支援視訊
只是leg的有點嚴重...
firezard
註冊時間: 03/08/2005 7:23 pm
#6 文章 firezard »
[Mercury] --- It's free !!!
What is Mercury ?
Mercury is a Java Based MSN client.
With Mercury you can do the same things as with your normal messenger:
Talk to friends
Change your nickname and status
Add a display picture (also know as avatar)
Send files through the msn server (for people with a firewall etc..) or direct
Play games (Tic Tac Toe and Connect4 only at the moment)
But Mercury has some extra functions that your normal messenger doesn't have, for example:
Be online with several MSN adresses at the same time.
Login with your status on 'Invisible' or any other status you want.
Have a different MSN name in every conversation... and more!
see [www.mercury.to]
