我在OS9.2.2之下用Script Editor Z1-1.7,意圖將一個動作 --- " Get Info --> Copy了Icon --> 開一個新的Folder --> Get Info --> Paste Icon " 錄製成一個 Apple Script。
但每次都出現 "Finder got an error: selection doesn't understand the <<event aevtcopy>> message."
錄製成的Apple Script如下:
tell application "Finder"
activate
open information window of selection
<<event aevtcopy>> selection
close information window
make new folder at desktop
end tell
到底有什地方錯了?還是Script Editor跟本不能做到?請指教。
[ 01-27-2002: 留言編輯者: dcc ]
Apple Script 的問題
Apple Script 的問題
dcc,
一,
動作 --- " Get Info --> Copy了Icon --> 開一個新的Folder --> Get Info --> Paste Icon " 跟本不能錄製。
二,
applescript 1.7 in Mac OS 9.2.2 is...
better to downgrade the applescript extension & standard addition to version 1.6.
三,
You need a marco utility to do the original task.
一,
二,
三,
Apple Script 的問題
這是否代表無論用1.7還是1.6都沒法做到呢?
另外,marco utility是什麼? [img]images/smiles/icon_confused.gif[/img]
[img]images/smiles/icon_smile.gif[/img] [img]images/smiles/icon_smile.gif[/img] [img]images/smiles/icon_smile.gif[/img] Thx [img]images/smiles/icon_smile.gif[/img] [img]images/smiles/icon_smile.gif[/img] [img]images/smiles/icon_smile.gif[/img]
Apple Script 的問題
dcc,
是, 無論用1.7還是1.6都沒法做到.
Your original task, try IconDropper, more info here:
http://www.iconfactory.com/
if you insist to use applescript to change the icon, you need some softwares to simulate the key stroke or mouse click, er, not a elegance way.
Quickeys :
http://www.cesoft.com/products/qkmac.html
Prefab player :
http://www.prefab.com/player.html
Quickeys :
Prefab player :
Apple Script 的問題
明白了 [img]images/smiles/icon_sad.gif[/img]
希望日後可以學多一些Apple Script的技巧,因為真的很方便 [img]images/smiles/icon_razz.gif[/img]
[img]images/smiles/icon_smile.gif[/img] [img]images/smiles/icon_smile.gif[/img] [img]images/smiles/icon_smile.gif[/img] Thanks [img]images/smiles/icon_smile.gif[/img] [img]images/smiles/icon_smile.gif[/img] [img]images/smiles/icon_smile.gif[/img]
