[Tiger 分享] Dictionary/Thesarus lookup
oeyvind
文章: 1990
註冊時間: 10/03/2001 1:01 am
來自: 大馬/星洲
#1 文章 oeyvind »
So you have a word you wanna lookup, in Tiger all you need to do is to hold down the command, control, d keys and hover over the word, and voila you get this:
最後由 oeyvind 於 04/30/2005 9:52 am 編輯,總共編輯了 5 次。
ulysses
Re: [Tiger 分享] 優雅的牛津英英字詞典
#2 文章 ulysses »
oeyvind 寫:So you have a word you wanna lookup, in Tiger all you need to do is to hold down the command, option, d keys and hover over the word, and voila you get this:
LiveDictionary 岌岌可危了...
oeyvind
文章: 1990
來自: 大馬/星洲
#3 文章 oeyvind »
ulysses 寫:為什麼看起來像是數位相機拍的? :oops:
ya ya, did not think abt using timed capture feature in Grab, just updated with another image.... ^^
Make a mistake on top as well, should be command control d
cesarlin
文章: 138
註冊時間: 06/26/2001 1:01 am
Re: [Tiger 分享] Dictionary/Thesarus lookup
#4 文章 cesarlin »
oeyvind 寫:So you have a word you wanna lookup, in Tiger all you need to do is to hold down the command, control, d keys and hover over the word, and voila you get this:
忍不住還是想問一下, 那Frosty Place 的 Frosty 是 1. 還是 2. 阿?
據我所知台北跟San Jose都不會降霜.
hsu912174
文章: 203
註冊時間: 10/18/2004 1:34 am
#5 文章 hsu912174 »
cesarlin 寫:
第4個
Of relation to the fruit so-called Apple. 8)
