X Icon 欣賞
Gordon
文章: 429
來自: Hong Kong
X Icon 欣賞
#1 文章 Gordon »
講真,靚就靚啦!如果想改HardDisk的icon是一件超級無敵麻煩,非一般人可以做到的呢!
Ascent
文章: 206
來自: G8
X Icon 欣賞
#2 文章 Ascent »
Under Mac OS X, the process differs only slightly. The Get Info window is now called the Inspector window but retains its command-i key sequence. Note also that only one Inspector window may be active at a time. The window may be kept open and it's contents will change depending on what is selected in the Desktop. Simply invoke the Inspector window for the icon that you would like to copy, copy its icon as before, select the icon to be replaced in the Desktop, and paste on the new icon through the Inspector window. That's all there is to it. [img]images/smiles/icon_eek.gif[/img]
Gordon
文章: 429
來自: Hong Kong
X Icon 欣賞
#3 文章 Gordon »
no no no!其他的icon就可以隨意copy/paste,但是要改hard drive ∕startup hard drive 的icon幾乎是不可能的事呢!如果像以前的方法copy and paste在 OS X 中是沒有改變的,但卻在OS 9中看到改變了的icon!
所以我覺得這一方面OS X 可以改變一下呢!
Ascent
文章: 206
來自: G8
X Icon 欣賞
#4 文章 Ascent »
多虧了OS X這個超肥系統,讓我們可以用這麼肥的icon…
圖檔 哈…漢堡硬碟…
圖檔 要猛?用這最猛!
圖檔 真是好看…
圖檔 嗯~Photoshop6…
呵呵~有興趣的人可以去 xicons.macnn.com 看看~ 圖檔 圖檔
[ 05-05-2001: 留言編輯者: Ascent ]
