Mac OS X 10.0.4 update is out!
heish
文章: 37
註冊時間: 06/10/2001 1:01 am
來自: USA
#1 文章 heish »
Still no DVD support, but finder and window resizing seem snappier. You be the judge.
Update Now
Use Software Update in your System Preferences to get Mac OS X v10.0.4, which includes:
Improvements for USB devices, including additional external device support for iTunes CD burning
Improved battery life for many PowerBook G3 systems
Improved Classic compatibility
Security updates to OpenSSH and 唼udo services
Support for the new active-matrix 17-inch Apple Studio Display
[ 06-22-2001: 留言編輯者: heish ]
mon
文章: 138
來自: Hong Kong
#2 文章 mon »
今天晚上回家試試....
[ 06-22-2001: 留言編輯者: 十二少 ]
dannis
文章: 17
註冊時間: 06/19/2001 1:01 am
來自: macau
#3 文章 dannis »
I tried to use the software update, but it said my software in up-to-date and didn't do nothing.
What should I do in order to update?
when I check the system profile, it appears my OS X is still v.10.0.3.
heish
文章: 37
來自: USA
#4 文章 heish »
dannis, go to www.versiontracker.com and you can download a standalone 10.0.4 update if your software update did not work. Cheers.
Gordon
文章: 429
來自: Hong Kong
#5 文章 Gordon »
報告!剛剛download o左10.0.4 update,而我是用OS X 中文的,它說那update不能用在我的電腦上!
我用的是PowerMac G4 450 MP!
有甚麼錯誤呢﹖
報告完畢
overmas1
文章: 68
註冊時間: 06/05/2001 1:01 am
來自: hk
#6 文章 overmas1 »
中英文的不同吧?
dannis
文章: 17
來自: macau
#7 文章 dannis »
<BLOCKQUOTE><font size="1" face="XYZ">quote:</font><HR>原始發信人 heish:
<STRONG>dannis, go to www.versiontracker.com and you can download a standalone 10.0.4 update if your software update did not work. Cheers.</STRONG><HR></BLOCKQUOTE>
heish, 我在versiontracker找到的只是10.0.4的combined版本,而我的系統己經是10.0.3, 理論上找updater就可以,但是,versiontraker內無這個file,我試用19mb那個,結果不能install. 而apple site我要的file又是dead link. 到現在我未可以update.
Any idea?
heish
文章: 37
來自: USA
#8 文章 heish »
dannis, here's the link to download the 10.0.3->10.0.4 updater. Hope this helps. Try it a couple times. It seems to be down sometimes...
http://til.info.apple.com/techinfo.nsf/artnum/n75142
[ 06-23-2001: 留言編輯者: heish ]
dannis
文章: 17
來自: macau
#9 文章 dannis »
<STRONG>dannis, here's the link to download the 10.0.3->10.0.4 updater. Hope this helps. Try it a couple times. It seems to be down sometimes...
[ 06-23-2001: 留言編輯者: heish ]</STRONG><HR></BLOCKQUOTE>
Thanks, I just downloaded the updater. But my new iBook doesn't allow me to install it. It gives me the wordings as "This software can't be isntalled in this computer". I have no clue at all. Could you give me further help on this!
Gordon
文章: 429
來自: Hong Kong
#10 文章 Gordon »
Dannis, I think you are using Chinese OSX 10.0.3, right? those updater is not support Chinese OSX now!
if you can notice the link of the updater is ".../1z/..."
but your Chinese OSX CD cover is "2z...". Did you notice that? in this point the reason why I think it is not yet support Chinese OSX
May be wait, or.... see my OSX 10.0.4 input Chinese message.
Good luck
