how to WARM BOOT
josephcool
文章: 45
註冊時間: 07/15/2001 1:01 am
來自: Hong Kong
how to WARM BOOT
#1 文章 josephcool »
How to WARM BOOT with MAC(like alt+ctrl+del in PC)??
Thanks!!
PS: my mac keyboard doesn't have THE KEY for reboot.
how to WARM BOOT
#2 文章 bryanchang »
command - control - power key
janusng
文章: 1048
來自: Metropolis Asylum
how to WARM BOOT
#3 文章 janusng »
請看MacProject的討論。
btw,reboot是cmd-ctrl-power!
josephcool
文章: 45
來自: Hong Kong
how to WARM BOOT
#4 文章 josephcool »
ar..............
which is the command key?
and which is the power key, is that the power switch in iMAC's panel?
thanks!!
how to WARM BOOT
#5 文章 bryanchang »
Since there is no power key on your iMac's keyboard, there must be a reset button (the one marked with a triangle logo) on the right side of the iMac, where all the ports are located.
Use that button will warm boot your iMac.
josephcool
文章: 45
來自: Hong Kong
how to WARM BOOT
#6 文章 josephcool »
ar......please tell me more in detail
I can't find the RESET button form my iMAC
thanks
how to WARM BOOT
#7 文章 bryanchang »
Go check it out yourself:
Apple iMac Support page
josephcool
文章: 45
來自: Hong Kong
how to WARM BOOT
#8 文章 josephcool »
I got it !! (reset hole)
on the connection panel
I didn't noticed that yesterday, haha
thanks!!!!!
