Viewing Chinese file name from SMB shares
wookie
文章: 3
註冊時間: 10/04/2001 1:01 am
來自: Hong Kong
#1 文章 wookie »
Hi,
I am running OS X 10.1 and connected to my Linux Samba shares. There are some MP3 files with Chinese file name. In OS X, all Chinese names become "rubbish" characters. But under Windows they are displayed fine. Anything I can do in my OS X to view Chinese file name? I can see Chinese in IE and Netscape...
wookie
the real unknown
冰果室打手
文章: 2610
來自: GMT-5
#2 文章 the real unknown »
請愛用 Window NT, Windows 2000, 及 Windows XP。
cktam
文章: 143
來自: 澳門-Macau
#3 文章 cktam »
you said, all file's name display fine under
windows, so what is the win version you are
using, windows9x, NT or 2000???
wookie
文章: 3
來自: Hong Kong
#4 文章 wookie »
Now it is Windows XP, but Windows 2000 worked before as well.
wookie
