大寶哥on Macbook Pro
kart
文章: 44
註冊時間: 12/28/2004 7:23 am
來自: USA
大寶哥on Macbook Pro
#1 文章 kart »
http://www.nytimes.com/2006/03/02/techn ... ted=1&_r=2
在期待阿西摩的軟體測試前先看到了大寶哥的文章
紐時的大寶哥對Macbook Pro評價還算滿高的
結論是就算不是全世界最好的筆電,可能也是相當接近的了
不過大寶哥也說了,目前相容的軟體還有待加強,所以他認為可能目前叫
Macbook Po比較適合~ :badgrin: Po for potential~ 呵呵~
不過不論如何,我對蘋果為啥要把以下這些東西拿掉或是退化實在也非常不解,這些成本應該不會很高,還是設計上會欲到瓶頸嘛?還是難道會讓電腦過熱這類硬體問題嘛? :x 總之,這讓我有點卻步想等下一代了 @@
拿掉或退化的東東:
(excerpt from David's article)
Now, Apple always giveth and taketh away. This time around, though, Apple hath taken away quite a few PowerBook features. The S-video connector, for high-quality TV playback of movies, is gone — a weird omission, considering the multimedia emphasis implied by the new remote control. (You can restore the S-video jack with a $20 accessory cable.) The FireWire 800 connector, for high-speed hard drives, is also missing. The DVD burner is only half as fast as the previous model (4X instead of 8X) and can no longer burn dual-layer DVD discs. Current PC expansion cards (including high-speed cellular Internet cards) don't work or fit in the new narrow-format ExpressCard slot.
Most mystifying of all, Apple has removed the laptop's dial-up modem, so you can no longer send or receive faxes. You can't go online in hotels that don't offer high-speed connections (or that charge way too much for them), either. Apple points out that you can buy its tiny external modem for $50, but that's another piece to pack, track and lose.
