multi-gnome-terminal
luisehsu
文章: 147
註冊時間: 07/04/2001 1:01 am
來自: Nowhere to Nowhere
#1 文章 luisehsu »
sorry this should be a unix question:
is there any terminal on mac os x like multi-gnome-terminal, which is able to use one terminal window to show multiple connection sessions identified by tab? i try to compile the source code but fail (not lib problem but error in marco)
as a user with small desktop, this is a ideal tool for me
thanks
louis
#2 文章 bryanchang »
Well, actually you don't need to compile the code, just install fink and multi gnome terminal is right in there.
http://fink.sourceforge.net/pdb/search.php?s=terminal
Don't you just love Mac OS X? [img]images/smiles/icon_smile.gif[/img]
謝孟叡
文章: 960
來自: 邪教組織 #osxchat
#3 文章 謝孟叡 »
<BLOCKQUOTE><font size="1" face="XYZ">quote:</font><HR>原始發信人 Luise:
<STRONG>sorry this should be a unix question:
thanks
louis</STRONG><HR></BLOCKQUOTE>
I prefer using screen.... [img]images/smiles/icon_razz.gif[/img]
see http://www.gnu.org/software/screen/
julian9
文章: 45
註冊時間: 11/22/2001 1:01 am
來自: Chicago, USA
#4 文章 julian9 »
覆議,screen比較好用...
luisehsu
文章: 147
#5 文章 luisehsu »
sorry for late response [img]images/smiles/icon_biggrin.gif[/img]
1. thanks for everyone's help
2. give up multi-terminal because it seems it hasn't been fully tested under darwin yet, and i am afraid that same problem would show up when trying to package it
3. screen is great, still prefer gui staff though [img]images/smiles/icon_rolleyes.gif[/img]
