我想用MAC 寫程式
不知可有在OS X下編C語言的編輯程式
有可以寫真C語言的程式嗎?(在OS X)
Yeah, cc is included.
cc is included only if you installed the developer kit.
you can get it from Apple website or sometimes it come with newer machines as a disk image file. It is shipped with retail version of Mac OS X as a separate CD.
I like Project Builder.. absolutely love Cocoa Programming...
it compiles and debugs every flavor of C (C, C++, Objective C) and Java using gcc.
- bryanchang
如果你有盒裝的 Mac OS X 的話,Developer Tools CD 是隨系統附的。
如果你是買新機器上有裝 Mac OS X 的話,Developer Tools 是存在硬碟裡的。
不管如何,你都可以在安裝好 Developer Tools 後使用 gcc 或蘋果的 Project builder.
- bryanchang
gpp? GNOME packaging project??
白老大,我想用gpp啊,有嗎?
- bryanchang
gcc 3.0 會在下一版的 Developer Tools 中支援。
謝謝! [img]images/smiles/icon_biggrin.gif[/img]
