如何叫出 Terminal.app 新視窗
謝孟叡
文章: 960
來自: 邪教組織 #osxchat
#1 文章 謝孟叡 »
xterm 可以從 command line 指定新窗子的大小位置,不知 terminal.app 是否能辦到?或者要動用 apple script, 我是個 applescript 白痴,is it possible?
文章: 610
註冊時間: 12/25/2001 1:01 am
#2 文章 »
The applescript support of Terminal.app is... Well, saving the time & effort for the next version of Terminal.app.
Unix way:
Use .term file to control the behaviour of terminal. Here's a tutorial from O'Reilly:
http://www.macdevcenter.com/pub/a/mac/2002/03/26/terminal_four.html
Tried 'man -k terminal', but none of the commands is suitable. Maybe we can't do it from command line?
