see chinese text in ipod
lhmjacky
文章: 4
註冊時間: 08/19/2002 1:01 am
來自: hong kong
#1 文章 lhmjacky »
any freeware to recommend, most of them i can't see chinese wording and better over 2000 words
tks in advance
oeyvind
文章: 1990
註冊時間: 10/03/2001 1:01 am
來自: 大馬/星洲
#2 文章 oeyvind »
Make sure you have the latest firmware (v1.2)... that should do the trick.
lhmjacky
文章: 4
來自: hong kong
#3 文章 lhmjacky »
yes, I installed v.1.2
and try text2ipod, podtext 2.0x by textedit
at mac os x 1.2, still can't see chinese wording
at ipod.
Tim Tam
文章: 6
註冊時間: 08/28/2001 1:01 am
來自: Australia
#4 文章 Tim Tam »
You can use the address book in Mac OS X 10.2
1.Make a new card
2.Insert a song name in the first name section, an artist in the last name section and Chinese lyric in the note section
3. Export the card in vCard format (Drag the card to the destkop)
4. Mount iPod as a Firewire harddisk
5. Drag the vCard in the contact folder
