如何復製密碼?
tsuchien
文章: 120
註冊時間: 01/03/2002 1:01 am
來自: Chartreuse-Vercors-Belledonnes
如何復製密碼?
#1 文章 tsuchien »
剛升級實驗室一臺PMac7600至G4/800跑MacOS X,教大家如何操作、改密碼。現在又升級另一臺PMac7500,請問如何復製第一臺的密碼至第二臺呢?like /etc/passwd + /etc/shadow
fddi1
文章: 188
註冊時間: 05/03/2001 1:01 am
來自: USA/Seattle, WA
如何復製密碼?
#2 文章 fddi1 »
MacOS X uses NetInfo to store the user information. So the easiest way to do it is to go to the NetInfo Manager and backup your local domain, then tar the entire directory. Move the tarball to the another machine and untar it. Then, restore the backup, and you should have an identical copy of the NetInfo DB.
tsuchien
文章: 120
如何復製密碼?
#3 文章 tsuchien »
<BLOCKQUOTE><font size="1" face="XYZ">quote:</font><HR>原始發信人 fddi1:
<STRONG>MacOS X uses NetInfo to store the user information.</STRONG><HR></BLOCKQUOTE>
謝謝...
今天剛收到MacOS X for Unix Geeks,現在正研究nidump, niload, nicl指令。
