解決Final Cut Pro 不能註冊的問題!!!!
harry2690
文章: 43
註冊時間: 11/07/2006 11:00 am
來自: 遙遠的外太空
#1 文章 harry2690 »
不知道有沒有人跟我一樣~在安裝的時候出現
"Licensing Error: The license file will not be written to disk because the user does not have enough privileges."
如果不管他繼續安裝~等到開啟後輸入資訊跟序號又出現一樣的東西~
真的煩死了~
後來上網爬阿爬~發現有人跟我有一樣的問題~
解決的方法是:
到HD>Library>Application Support>ProApps
然後把裡面的Final Cut Pro System ID砍掉,再重新開啟程式並輸入資訊就可以了~~~
以下是原文:
if you have this problem like i hade...
then you have to go into the HD>Library>Application Support>ProApps folder and remove the 'FCP System ID' file. I don't know why it works, but it works...
資料來源:http://thepiratebay.org/tor/3513356/Final_Cut_Pro_5.1_Universal
有需要的人看看吧~
