求救!!
brianwuu
文章: 60
註冊時間: 09/26/2007 11:05 pm
求救!!
#1 文章 brianwuu »
剛剛想去找一個能讓mac leopard 能夠收hotmail信箱的網站,就在apple的網站看介紹的這個軟體:
www.automagic-software.com/
但是安裝完後並沒有反應 也收不了信 (可以寄出,  但信箱收不了信)於是就要把他刪除,我按照他的步驟:
1. To de-install the plugin, you must delete the httpmail.mailbundle folder in the Bundles
folder of the current user. The path is likely to be: Macintosh HD / Users / [current user
name] / Library / Mail / Bundles. You should also delete any httpmail accounts you have
created before uninstalling the plugin.
2. Then you may then de-activate the Mail plug-in facility by executing the following
command in a Terminal window, paying great attention to the exact spelling:
defaults write com.apple.mail EnableBundles
但是第二點 我實在是看不懂 請問誰可以告訴我第二句話的意思為何?
另外 ,有人已經可已在leopard 上用mac 的mail收hotamil的信了嗎??
Changhsin
文章: 1279
註冊時間: 01/06/2003 2:55 pm
Re: 求救!!
#2 文章 Changhsin »
brianwuu 寫: 2. Then you may then de-activate the Mail plug-in facility by executing the following
它請你在終端機底下輸入指令,並且請你注意別打錯字了。
終端機程式在 Applications > Utilities > Terminal
