10.5.2 MBP 蓋上蓋子以後無法喚醒電腦?
eshowl
文章: 270
註冊時間: 09/16/2006 8:47 am
來自: PA, US
#1 文章 eshowl »
昨天更新了 10.5.2 以後碰到了這個怪問題
我之前是用 MBP 接 Apple Cinema 螢幕
之前的操作方式是開機, 蓋上機蓋, 用滑鼠喚醒電腦, 用 Cinema 螢幕來使用
但是昨天更新到 10.5.2 以後
每次用滑鼠喚醒MBP, Cinema 上畫面會閃一下, MBP 會醒來一下下, 但是會馬上再進入睡眠狀態...
請問該怎麼解決?一定要把 MBP和螢幕並列放一起做雙螢幕嗎?(桌子很小)
若想降回 10.5.1 該怎麼做呢?
謝謝!
Apple 討論區好像也有很多人遇到一樣的問題...
http://discussions.apple.com/thread.jsp ... ID=6590440
Today I connected the MacBook Pro to my Apple Cinema Display at work, per usual. Pressed the power button and closed the lid. The desktop background appeared on the ACD and then went blank. Typically I press a key on my external keyboard and the ACD comes on with the full desktop at max resolution. Now, the ACD comes on briefly with the desktop background only and then the MacBook Pro goes to sleep. Pressing a key on the external keyboard revives the ACD briefly followed by the same sleep behavior. Upon opening the lid on the MacBook Pro the screen is black and the keyboard is unresponsive. A forced restart is needed.
I have tried connecting the display after fully starting the laptop and the same behavior results. I have also repaired permissions and reset the PMU. Neither had any effect on the behavior.
So far, I can't use the ACD with the MacBook Pro with 10.5.2.
看來目前是無解,似乎是最後那個 Graphic Update 出了問題...
chien_bin
文章: 21
註冊時間: 02/13/2008 11:13 am
Re: 10.5.2 MBP 蓋上蓋子以後無法喚醒電腦?
#2 文章 chien_bin »
eshowl 寫:昨天更新了 10.5.2 以後碰到了這個怪問題
但是昨天更新到 10.5.2 以後
若想降回 10.5.1 該怎麼做呢?
謝謝!
我的狀況跟大大一樣耶
請問,現在還是無解嗎?
kevin.forsty
註冊時間: 04/14/2007 2:55 pm
#3 文章 kevin.forsty »
我試過很多方法, 都不管用 ..... 最後系統全部重灌.. 就好了 !! 又恢復正常 ...
chien_bin
文章: 21
#4 文章 chien_bin »
kevin.forsty 寫:我試過很多方法, 都不管用 ..... 最後系統全部重灌.. 就好了 !! 又恢復正常 ...
之前 update 一個什麼東東的,就一切沒問題了。
真開心。
