Power Mac G5 2.0 DP (PCI-X 2)
版主: Alex Tsaichestercjtai
georgelien
文章: 161
註冊時間: 03/14/2002 1:01 am
#1 文章 georgelien »
$50,000TWD, Anyone?
It's in Taipei, Taiwan.
Introduction Date: June 9, 2004
Discontinued Date: April 27, 2005
Processor: 2.0 GHz PowerPC 970fx (G5) x2
System Bus Speed: 1.0 GHz (2:1) Cache Bus Speed: 2.0 GHz (Built-in)
ROM/Firmware Type: Open Firmware ROM/Firmware Size: 1 MB
L1 Cache: 32k/64k L2/L3 Cache: 512k
RAM Type: PC3200 DDR Min. RAM Speed: 400 MHz
Standard RAM: 512 MB Maximum RAM: 8.0 GB
Video Card: GeForce FX 5200 Ultra VRAM Type: DDR SDRAM
Details: The NVIDIA GeForce FX 5200 Ultra with 64 MB of DDR SDRAM occupies an 8X AGP Pro slot.
Standard Hard Drive: 160 GB (7200 RPM) Int. HD Interface: Serial ATA (1.5Gb/s)
Standard Optical: 8X "SuperDrive" Standard Disk: None
Standard Modem: 56k v.92 Standard Ethernet: 10/100/1000Base-T
USB Ports: 3 (2.0) Firewire Ports: 2 (400), 1 (800)
Details: The Power Mac G5 has three USB 2.0 ports on the system (one on the front panel and two on the back), two Firewire "400" ports (one on the front and one on the back), and one Firewire "800" port on the back. Apple also advertised "two USB 1.1 ports on included keyboard".
Also see: Complete Ports.
Expansion Slots: 3 PCI-X, AP/BL Expansion Bays: 2 3.5"
Details: This model has "three open full-length PCI-X slots: one 133MHz, 64-bit slot and two 100MHz, 64-bit slots", an 8X AGP Pro slot that "supports up to 2-GBps data throughput" and is occupied by the graphics card, as well as expansion slots for AirPort Extreme (802.11g) and Bluetooth 1.1.
*This model is capable of using MacOS 9 applications within the MacOS X "Classic" environment provided with MacOS X 10.4.11 "Tiger" and lower ("Classic" is not supported starting with MacOS X 10.5 "Leopard"). It cannot boot into MacOS 9.
Site-sponsor OHS specializes in heavily upgraded Macs capable of running both MacOS X and MacOS 9 applications.
Dimensions: 20.1 x 8.1 x 18.7 Avg. Weight: 44.4 lbs. (20.2 kg)
