請問各位
就 Help 上面的解釋來說
Bonjour 的使用是不需要做任何設定的
只要在 Connect to Server 上面填上正確的 Bonjour 位置就好
例如 My-Mac.local
可是我怎麼都找不到
錯誤訊息都是說 Can't resolve link-local name
請問是需要再額外做設定嗎?
Bonjour doesn't work
Fortune favors the bold.
- Virgil (70 BC - 19 BC)
抱歉沒有描述清楚:
1. Environment
Device:
- Macbook Pro with "Allow all incoming connections" in "Firewall" setup
- iPhone (no jailbreak, with application installed to support Bonjour/WebDAV file sharing)
Network:
- Connected via WiFi router in one subnet 192.168.11.xxx
2. Symptom
- After launching the application (server), iPhone is accessible by its IP address, and can be mounted as an external disk by "Connect to Server" and WebDAV
- While trying to use its Bonjour name, however, "Connect to Server" shows the error message: server can't be found on the network.
- I try to connect the Macbook Pro itself via its Bonjour name and the same error result
1. Environment
Device:
Network:
2. Symptom
