Dropbox 新活動 - 可以獲得3GB額外免費的空間
applewoodstock
文章: 130
註冊時間: 05/24/2008 12:18 am
#1 文章 applewoodstock »
只要您邀請你的朋友加入~
或者想新加入的朋友可以用這個活動,每邀請一個朋友(你的朋友也可以獲得250MB),可以多獲得250MB~
最多可以獲得3GB
You can earn 250MB (500MB if you're a subscriber) for each friend you refer to Dropbox. Referrals let you earn up to 3GB of extra space (6GB if you're a subscriber) just for inviting your friends to join Dropbox! All it takes is 3 easy steps.
This is mine, if you don't have dropbox
https://www.getdropbox.com/referrals/NTQzMjQ2OQ :badgrin:
