我有一臺Caldigit 500G 舊款 http://www.frostyplace.com/index.php?story_id=6085 可是我亂存,目前設在Proted/Raid1因為我也不太懂硬碟,現在我想把兩顆250G的資料,分開拿出來,它可以裝在一個外接盒是嗎?除此之外有別的辦法嗎?因為在法國比較貴真不想在法國買外接盒。
我可以把它連在Mac mini server
Dual 500G 嗎?因為它是server 我還不太懂,而且主要的是Celdigit 資料要分開拿出來。要如何讓Celdigit 不要作鏡面同步?
要如何讓Caldigit 不要作鏡面同步?
最後由 auplume 於 12/30/2010 6:48 am 編輯,總共編輯了 1 次。
ahann241 寫:他不是從背後調整成 JBOD 就變成單純分開的兩顆硬碟了嗎?還是我記錯了?
you need to wipe out all the data and
partition two drives separately. 這句話我不懂?可否幫忙解釋?
我的資料存在 protected模式從來沒變過,現在我要把他們不同步,我是不是可以這樣作:
照它下面說的我是可以先把FireWireVR調到JBOD模式再從Utility調整。
照FireWireVR關機
調到JBOD模式
再開 FireWireVR
從電腦的Utility .....
http://www.caldigit.com/faq.asp#FWVRRAID1
How to configure FireWireVR drives in RAID1 (Protected Mode) properly?
Whenever you want to switch from JBOD, Performance, or Concatenated
mode to Protected mode (RAID1)- you need to wipe out all the data and
partition two drives separately. First under JBOD, then rotate switch
to PROTECTED MODE. For example, if you are in Performance mode and you
intend to switch to Protected mode, you need to do the following:
1. Unmount volume and turn off FireWireVR.
2. Rotate switch to JBOD.
3. Turn FireWireVR power on.
4. Go to Disk Utility or Disk Management and partition these two
drives individually.
(This is to make sure you have identical drives and contents before
switching to RAID1.)
5. Unmount JBOD volumes then turn off FireWireVR.
6. Rotate RAID switch to Protected, then turn FireWireVR on.
7. Use Disk Utility or Disk Management to partition RAID drive.
Notes: Failure to follow this procedure may cause drive problems
and/or data loss
