powerbook G4 1.67 ~有無光纖輸出埠呢?
Angent
文章: 435
註冊時間: 11/08/2001 1:01 am
來自: taipei city
#1 文章 Angent »
請教各位~
感謝~
老殊
文章: 1113
來自: San Cala
Re: powerbook G4 1.67 ~有無光纖輸出埠呢?
#2 文章 老殊 »
Angent 寫:請教各位~
感謝~
根據lowendmac網頁, 17"PB4 1.67是有optical I/O的
Angent
文章: 435
來自: taipei city
#3 文章 Angent »
感謝歐!
Angent
文章: 435
來自: taipei city
#4 文章 Angent »
老殊 寫:
Angent 寫:請教各位~
感謝~
但小弟的是15吋...
老殊
文章: 1113
來自: San Cala
#5 文章 老殊 »
http://guides.macrumors.com/PowerBook_G4_%2815-inch%29
是Rev. C吧? 那應是配備光纖輸出/入了
Rev. C
Released on 1/31/2005
[edit]
Specifications
* Processor: PowerPC 7447a/ 7447b G4
o Processor Speed: 1.5 GHz or 1.67 GHz
o Cache: 64k L1, 512k on-chip (1:1) L2
* System Bus: 167 MHz
* Hard Drive: 80 GB 5400-rpm or 100 GB 5400-rpm
* Media: 2.4x/8x/16x/6x/24x/24x DVD±RW/DVD+DL/CD-RW SuperDrive
* Trackpad: Solid-state trackpad supports tap, double-tap and drag
* Keyboard: Full size (78 (U.S.) or 79 (ISO) keys including 12 function, four arrow, embedded keypad), backlit with ambient light sensor
* Weight and Dimensions: 2.5 kg, 2.8 cm H x 34.8 cm W x 24.1 cm D; 5.6 lbs, 1.1 in H x 13.7 in W x 9.5 in D
* RAM: Maximum 2 GB, PC2-4200 DDR2 SDRAM at 333MHz 200-pin SO-DIMM, 2 slots
* Graphics Chip: 64 MB or 128MB DDR SDRAM ATI Mobility Radeon 9700 (AGP 4x)
o Display: 15.2" active matrix TFT, 1440x960 native resolution
o Display Connections: Dual-link DVI and S-Video
* Built-in 54-Mbps Airport Extreme
* Built-in Bluetooth 2.0+EDR
* One Firewire 800 port; One Firewire 400 port; Two USB 2.0 ports; Type I/II PC Card slot
* Combined optical digital input/audio line in
*Combined optical digital output/headphone out
