about Cube G4 - help
children
文章: 4
註冊時間: 01/29/2002 1:01 am
來自: Hong Kong
#1 文章 children »
I have some problems about my Cube G4.
1. I use firewire to correct a Maxtor 80G hard dice. But the hard dice always hang. I unplug the firewire and plug in again (1 time or few times)
than it works again.
2. After I update the OS to 9.2.2. , I boot the computer & it shows a "small bomb"(instead the mouse icon). I need to reboot the computer again.(It happens on every frist time power on the computer. )
3. It use long time to startup . (about 5 to 10 minutes)
4. It is possible to change the internal hard dice on
Cube?
Please help! Thank you very much! [img]images/smiles/icon_eek.gif[/img]
oldmic
文章: 31
註冊時間: 01/30/2002 1:01 am
來自: Hong Kong
#2 文章 oldmic »
Have you make down the message appear besides the little bomb? There may be some hints about the problem in the message.
children
文章: 4
來自: Hong Kong
#3 文章 children »
There is no message appear besides the little bomb. Just a little bomb only.
