UBB Code is a variation on the HTML tags you may already be familiar with. Basically, it allows you to add functionality or style to your message that would normally require HTML. You can use UBB Code and HTML together in the forums. You may want to use UBB Code as opposed to HTML because there is less coding required and it is safer to use (incorrect coding syntax will not lead to as many problems).
<img src=http://www.IMAGE_ADDRESS_HERE>
www.prime-web.com
UltimateBB.com
<A HREF="mailto:ted@prime-web.com">ted@prime-web.com</A>
Hello,
James
Hello,
Mary
<BLOCKQUOTE><font size="1" face="XYZ">quote:</font><HR>Ask not what your country can do for you....
ask what you can do for your country.<HR></BLOCKQUOTE>
