new PowerBook g4
oeyvind
文章: 1990
註冊時間: 10/03/2001 1:01 am
來自: 大馬/星洲
new PowerBook g4
#1 文章 oeyvind »
Can't wait to see more of the PowerBook?
Head down to suyama-san's great site: http://suyama.co.jp/
As you can see, the 12" is an iBook actually no matter want they want to call it... ^^
the real unknown
冰果室打手
文章: 2610
來自: GMT-5
#2 文章 the real unknown »
At least they moved the AC port to the left side with all the other ports. That makes docking easier.
But how can they call it a "full feature" notebook when it does NOT have a PC card slot? Ha!
640MB RAM max is pretty low, too. It doesn't seem to have any L3 cache either.
It is an soup-up iBook. It's... it's... CHEATING!
pmg4lktan
文章: 800
註冊時間: 12/17/2001 1:01 am
來自: 大馬
#3 文章 pmg4lktan »
The Real Unknown 寫: It is an soup-up iBook. It's... it's... CHEATING!
perhaps we should call it "iBook G4"? :lol:
so ... the "iBook G4" uses GeForce 4 Go MX 420 ...
how about the 17" TiBook?
有誰知道嗎?謝謝 ... :)
Best regards from,
pmg4lktan
Best regards from,
pmg4lktan
oeyvind
文章: 1990
來自: 大馬/星洲
#4 文章 oeyvind »
if you can find the specs of the 12" iBook g4... then you should also know the 17" giant uses GeForce4 440 Go/64M DDR.
speed wise for GPU (if I remember right)
ATI RM7500 > GeForce4 420 Go > ATI RM9000 > GeForce4 440 Go
GeForce4 has higher power consumption than ATI's (correct me if I'm wrong)
pmg4lktan
文章: 800
來自: 大馬
#5 文章 pmg4lktan »
pmg4lktan 寫: how about the 17" TiBook?
有誰知道嗎?謝謝 ... :)
查到了... 是 Go 440 ... :(
Apple 合時才會用 Go 460 呢? :roll:
P/S : 多謝 oeyvind 的回應 (小弟慢一步 send 了 :lol:)
Best regards from,
pmg4lktan
Best regards from,
pmg4lktan
janusng
文章: 1048
來自: Metropolis Asylum
#6 文章 janusng »
oeyvind 寫:if you can find the specs of the 12" iBook g4... then you should also know the 17" giant uses GeForce4 440 Go/64M DDR.
更正,該是420 Go > 440 Go > RM7500 > RM9000。
引用自Tom's Hardware Guide
Power Saving就更是420 Go > 440 Go > RM7500 > RM9000!
顏色上Nvidia Cards更不用說了,Steve Jobs為何選中GeForce? :evil: :x :evil:
oeyvind
文章: 1990
來自: 大馬/星洲
#7 文章 oeyvind »
Anyway PB G4 makes a great UNIX machine anytime:
Me fooling around with Apple X11
最後由 oeyvind 於 01/09/2003 8:14 pm 編輯,總共編輯了 1 次。
LensterWu
文章: 6
註冊時間: 01/08/2003 7:58 pm
#8 文章 LensterWu »
但這也不盡然,
因為Tom's的評比是在PC NB上的表現,
Mac OS X可不支援DirectX阿!
所以話也別說的太滿,
再看看表現吧...
janusng 寫: 更正,該是420 Go > 440 Go > RM7500 > RM9000。
pmg4lktan
文章: 800
來自: 大馬
#9 文章 pmg4lktan »
janusng 寫:Steve Jobs為何選中GeForce? :evil: :x :evil:
除非 ATI 有 Radeon Mobility 9700 囉 ...
小弟真是妄想! :(
Best regards from,
pmg4lktan
Best regards from,
pmg4lktan
luisehsu
文章: 147
註冊時間: 07/04/2001 1:01 am
來自: Nowhere to Nowhere
#10 文章 luisehsu »
Me fully around with Apple X11
For one not really relative question:
Is there any problem or issue we have to pay attention to during installing X11 package from Apple while Xfree86 4.2 installed already?
Thanks
Fortune favors the bold.
- Virgil (70 BC - 19 BC)
janusng
文章: 1048
#11 文章 janusng »
如果說DirectX的result不能作準的話,唯一理由是ATI的DirectX driver比nVidia好,而ATI的Quartz/QuickTime driver又比nVidia的差。但這不是事實。
ATI的Windows driver不及nVidia已是人所共知的,至於在OS X上的driver+hardware比較,可以參考Mac's Only的報告。雖然不是MR9K比GF4go440,但明顯地,ATI在Mac platform上,比nVidia更有利。
如果要solid proof的話,要等有人post新PowerBook 17"的Result上網再作比較。
LensterWu 寫:但這也不盡然,
所以話也別說的太滿,
再看看表現吧...
LensterWu
文章: 6
#12 文章 LensterWu »
小弟後來再找找資料,
我還是只能確定MR9K是最好的選擇,
後面的排名就不確定了 :?
雖然心中有點遺憾,
可是最遺憾的是12"PB沒有L3 cache跟ambient light sensor!!! :evil:
前者在速度上不知道會影響多少,
後者讓我失去在暗暗的會議室或房間中可以方便使用的機會... :evil:
janusng
文章: 1048
#13 文章 janusng »
在15" PowerBook 1G上,L3 Cache在大多數的程式上大約會打七折,12" PowerBook上應該影響少些,一來867是6.5x system bus,比1G的7.5x低,二來867有DDR RAM。
請參考香港rhapsody的討論
不過,有些特別的軟件,如VPC,沒有L3的話,只有兩成速度
the real unknown
冰果室打手
文章: 2610
來自: GMT-5
#14 文章 the real unknown »
janusng 寫:在15" PowerBook 1G上,L3 Cache在大多數的程式上大約會打七折,12" PowerBook上應該影響少些,一來867是6.5x system bus,比1G的7.5x低,二來867有DDR RAM。
哈哈。那個蘋果才有的DDR/2(除以二)會有多大幫助?
janusng
文章: 1048
#15 文章 janusng »
mmm...都有少少作用的,一來DDR的chip,一般比SDR的快,可以省到一個或半個cycle輸出critical word,相當於867的6/3 CPU cycles或1G的7/3 CPU cycles。
二來,DDR可以令FSB和AGP更飽和,十個bubbles中,減少一兩個也是好的。
不過DDR SODIMM可貴多了! :shock:
