OS X crash while launching classic application
luisehsu
文章: 147
註冊時間: 07/04/2001 1:01 am
來自: Nowhere to Nowhere
#1 文章 luisehsu »
As title, already happened twice after upgrading to 10.2.3:
1. While the OS 9 start-up window closing and application window pop-up, whole screen just freezes, still can move cursor though.
2. No response to hot key of force-quit, can't remote login to the machine either
It seems independent of specific OS 9 app 'cause each time was different app (Photoshop 5, Tex-Edit Plus)
Is there anyone having the same experience?
Thanks
Fortune favors the bold.
- Virgil (70 BC - 19 BC)
pmg4lktan
文章: 800
註冊時間: 12/17/2001 1:01 am
來自: 大馬
Re: OS X crash while launching classic application
#2 文章 pmg4lktan »
nian-shau shiu 寫:As title, already happened twice after upgrading to 10.2.3:
Thanks
well ... can you boot from the OS 9 volume? what version is it (9.1, 9.2.2 ...)?
yoou might also try getting the carbon or cocoa version instead of using the classic version ... Good luck! ;)
Best regards from,
pmg4lktan
Best regards from,
pmg4lktan
luisehsu
文章: 147
#3 文章 luisehsu »
pmg4lktan 寫: well ... can you boot from the OS 9 volume? what version is it (9.1, 9.2.2 ...)?
Best regards from,
pmg4lktan
thanks for your reply!
classic version is os 9.2.2 and yes, i can boot from os 9
the only reason i have to enable classic environment is for better chinese input method: han-ing :roll:
