有沒有任何一款usb軟碟機是可以在vpc下使用
smallmt
文章: 2
註冊時間: 06/12/2002 1:01 am
來自: taipei
#1 文章 smallmt »
如題
因為必須用pc的系統且需要使用到軟碟
如果我用vpc在我的ibook上的話
有沒有任何一款usb軟碟機是可以在vpc下使用的
thanks
pmg4lktan
文章: 800
註冊時間: 12/17/2001 1:01 am
來自: 大馬
Re: 有沒有任何一款usb軟碟機是可以在vpc下使用
#2 文章 pmg4lktan »
smallmt 寫:如題
因為必須用pc的系統且需要使用到軟碟
如果我用vpc在我的ibook上的話
thanks
根據 Connectix 所提供 Virtual PC 常見問題(FAQ) :
Q. Can I use my USB device with Virtual PC for Mac?
A. Yes. USB keyboards, mouse devices, and floppy drives connected to your Macintosh are
automatically shared with a virtual machine.
To use other supported USB devices with a virtual machine, two components are required:
· Windows 98, Windows Millennium (Me), Windows 2000, or Windows XP. Note: Windows 95, Windows NT and DOS do not support USB.
· Windows 98/Me/2000/XP drivers for your USB device (provided by the manufacturer)
Q. How do I use a USB device in Virtual PC for Mac?
A. USB devices can be used either by the Mac OS or by Virtual PC but not both simultaneously. The USB devices currently attached to your Mac appear in the USB tab in the Virtual PC preferences. You select which USB devices you want Virtual PC to use. USB devices must have a Windows 98, Windows Me, Windows 2000, or Windows XP driver supplied by the device manufacturer. Mac OS-only devices are not supported. Virtual PC does not include device drivers for specific USB devices. You must install the device driver for each USB device you want to use within Virtual PC.
希望能幫到您吧!祝您好運! ;)
Best regards from,
pmg4lktan
Best regards from,
pmg4lktan
