現在透過系統更新可以安裝 Apple Java 1.4.1
新增的項目包括:
* Improved Java applet support for Safari and other web browsers that support the Java Internet Plug-In.
* Up-to-date with the latest Java release from Sun, with hundreds of new features, including built-in support for XML-based web services, enhanced client functionality, and improved performance and reliability.
* Java applications take better advantage of Aqua and Quartz Extreme.
* Java applications now fully leverage the built-in Universal Access features of Mac OS X v10.2.
* Java applications can now be controlled through AppleScript, via the new UI Scripting technology (http://www.apple.com/applescript/GUI/).
Apple Java 1.4.1 更新
Apple Java 1.4.1 更新
void
sched_init(void){
sched_init(void){
Re: Apple Java 1.4.1 更新
裝完之後會發現 /Applications/Utilities/Java/ 裡面多了一個叫做 Input Method Hotkey 的小程式...謝孟叡 寫:現在透過系統更新可以安裝 Apple Java 1.4.1
程式裡面的描述 寫:Type your favorite input method hot key combination. When you press this hot key while a Java technology application has the focus and if multiple input methods are available, a pop up menu appears that let you select an input method.
- pauldaniel
- 常吃冰
- 文章: 413
- 註冊時間: 09/09/2001 1:01 am
- 來自: Taiwan
小弟不知道這個好處在哪裡ㄋ...... 能不能解釋ㄚ??????digdog 寫:裝完之後會發現 /Applications/Utilities/Java/ 裡面多了一個叫做 Input Method Hotkey 的小程式...謝孟叡 寫:現在透過系統更新可以安裝 Apple Java 1.4.1
