Please help me to format my Maxtor D740X ATA-133 Drives
Oumao
註冊時間: 05/15/2002 1:01 am
來自: Hong Kong
#1 文章 Oumao »
I bought one Acard AEC-6880M ATA-133 RAID PCI-Adaptor installed in my Power Macintosh 8500/250 with a Sonnet G3/500 CPU Upgrade Card. I try to connect two Maxtor D740X Ultra ATA 133 Drives for RAID 0 stripping. I have followed
all the Acard Manual instructions but I got an error message when I try to initialize the drives using Apple Drive set up as follows:
Assertion (!localError) failed in "PatchWriteDriver.c" on line 64
My Mac is on Mac OS 9.1. In Apple System Profiler, I can see the Acard controller card and two drives attached. However, these two drives cannot be mounted as I cannot format it at all.
Can everyone tell me what I should do in order to use my drives?
lcctno
文章: 34
註冊時間: 10/11/2004 7:41 am
#2 文章 lcctno »
i thought you forget to set jumper (master & slave) please check hard cover drawing
