下載地點及介紹
http://gaim.sourceforge.net/
GAIM 這套即時通訊軟體整合了ICQ, MSN Messenger, Yahoo, IRC, Jabber, Gadu-Gadu, and Zephyr networks,如果你有各種即時通訊軟體的帳號,全部使用得安裝每一種軟體又嫌麻煩的朋友,GAIM 可以說是您的救星了!
而且它支援windows, linux, 免費軟體!!!
我在mac上用proteus, PC上就用GAIM.
PC上的Proteus, GAIM!!!
Re: PC上的Proteus, GAIM!!!
真是贊!cktam 寫:下載地點及介紹
後來發現GAIM有一個小缺點,就是中文輸入無法用連續辭句輸入,連續在選字框中打了好幾個字,按Enter時卻只輸入最頭的那個字而已!cjtai 寫:真是贊!cktam 寫:下載地點及介紹
用了幾天決定放棄,因為無法連續輸入中文實在太痛苦了!...cjtai 寫: 後來發現GAIM有一個小缺點,就是中文輸入無法用連續辭句輸入,連續在選字框中打了好幾個字,按Enter時卻只輸入最頭的那個字而已!
無法連續輸入還好,不曉得溪偕兄有沒有用過 PC 上的 ICQ Lite,輸入對話的時候如果不小心按到 ESC 鍵......整個對話框都不見了。cjtai 寫:用了幾天決定放棄,因為無法連續輸入中文實在太痛苦了!...
沒辦法,誰叫我要用微軟新注音
在他們的「What is gaim」web page上,有提及MacOS X的,但是我在他們的download page上又找不到MacOS X的package。
請問那位大大知道在那兒可以找到?GAIM on X11 with GTK不算MacOS X吧!
Gaim is a multi-protocol instant messaging client for Linux, BSD, MacOS X, and Windows. It is compatible with AIM (Oscar and TOC protocols), ICQ, MSN Messenger, Yahoo, IRC, Jabber, Gadu-Gadu, and Zephyr networks.
Gaim users can log in to multiple accounts on multiple IM networks simultaneously. This means that you can be chatting with friends on AOL Instant Messenger, talking to a friend on Yahoo Messenger, and sitting in an IRC channel all at the same time.
Gaim supports many features of the various networks, such as file transfer (coming soon), away messages, typing notification, and MSN window closing notification. It also goes beyond that and provides many unique features. A few popular features are Buddy Pounces, which give the ability to notify you, send a message, play a sound, or run a program when a specific buddy goes away, signs online, or returns from idle; and plugins, consisting of text replacement, a buddy ticker, extended message notification, iconify on away, and more.
Gaim integrates well with GNOME 2 and KDE 3.1's system tray, as well as Windows's own system tray. This allows you to work with gaim without requiring the buddy list window to be up at all times.
Gaim is under constant development, and releases are usually frequent. The latest news regarding Gaim can be found on the news page.
- millerliang
- 文章: 42
- 註冊時間: 08/02/2001 1:01 am
- 來自: taiwan_taipei
Gaim 不好用,建議用 Mirandaim 比較好用,不過中文問題跟 proteus 一樣,YAHOO 跟 AIM 中文可收但看不到是亂碼。
http://www.miranda-im.org/
gaim Win32 does CJKV correctly, even does Right to Left if you need.millerliang 寫:Gaim 不好用,建議用 Mirandaim 比較好用,不過中文問題跟 proteus 一樣,YAHOO 跟 AIM 中文可收但看不到是亂碼。
