Resest DVD Player's Region Code
kulong
文章: 62
註冊時間: 05/05/2001 1:01 am
來自: U.S.A./Houston
#1 文章 kulong »
I bought some DVDs from China and watched them on my Power Mac G4. After a while, I used up (not knowingly) all five chances to change the region code on my SuperDrive. I searched on the web for ways to reset it but found no relevant information. If anyone could help it would be deeply appreciated.
#2 文章 ross_tt »
kulong
文章: 62
來自: U.S.A./Houston
#3 文章 kulong »
Thanks for the link, but I'm running the "Mirror" version of Power Mac G4 and therefore can't reboot in OS 9. I tried running apps such as DVDReset under classic but didn't work.
Are there any other workarounds?
