關於iPod週邊Belkin iPod Voice Recorder這個東西
gwenfly
文章: 16
註冊時間: 11/13/2003 8:29 am
#1 文章 gwenfly »
我是很需要錄音
不過他寫這樣
The Belkin iPod Voice Recorder is a great solution for iPod users who have something memorable to say. Now you can record memos, lectures, interviews, or conversations - simply by plugging the Voice Recorder into your iPod.
The Belkin iPod Voice Recorder works with the iPod with dock connector.
The iPod's abundant storage capacity lets your record hundreds of hours of high-quality voice recordings. You can easily review your audio notes using the built-in speaker, your earbud headphones, or your computer. Just like your music, your voice memos will sync automatically to iTunes (version 4.1 required) for storage, editing, or sending to others via e-mail. Your Voice Recorder even works as a travel alarm clock. The Belkin Voice Recorder brings a whole new dimension to your iPod.
這是指說這個Voice Recorder必須要插在iPod上而iPod需要插在Dock上才能使用嗎?
因為我並沒有PowerBook...只有桌上型,那想帶在身上隨時錄東西不就不行了??
英文好的大大麻煩幫我解惑吧 :oops:
#2 文章 bryanchang »
"The Belkin iPod Voice Recorder works with the iPod with dock connector. " 這句話的意思是說 iPod Voice Recorder 只與最新一代的 iPod 相容。
Impreza
文章: 573
註冊時間: 10/14/2003 7:16 pm
來自: 群山中
Re: 關於iPod週邊Belkin iPod Voice Recorder這個東西
#3 文章 Impreza »
gwenfly 寫:我是很需要錄音
不用帶著Dock,而是插在iPod的Dock的接頭上。
gwenfly
文章: 16
#4 文章 gwenfly »
了解啦!多謝!
