Mac OS X 10.4 新功能心得分享
#1 文章 bryanchang »
隨著 Mac OS X10.4 Tiger 開始陸續寄交到訂購者的手上,如果有經驗想要分享的朋友們,歡迎在本區張貼心得。
為了要讓網友們可以一目了然,請在心得分享的標題前面加上 [Tiger 分享] 字樣,感謝大家的合作。
最後由 bryanchang 於 10/27/2007 12:10 am 編輯,總共編輯了 1 次。
Jeff Chen
文章: 94
註冊時間: 01/14/2005 4:11 am
來自: Taiwan and live in San Francisco
I just got my new Imac today but ....need help
#2 文章 Jeff Chen »
Hi Bryant:
Can I get rid of " widgets" out of 10.4 system. I don't like it. It make me crazy. Every time I try to click on file. If I didn't click on the right place the widgets poping up. So I trash all the widgets file. but the widget still there.
Thannks
Jeff
#3 文章 bryanchang »
Jeff, what mouse are you using? I suspect this has nothing to do with Dashboard, but your mouse's shortcut key setup is wrong: Somehow you set the mouse so that when you click it "press" the F12 key, which in turns calls out the widgets.
