Any program for mac that i can set up a mail or bbs server
Mac OS X 平台上程式設計的相關問題討論
版主: bryanchangdigdog謝孟叡
gary1103
文章: 23
註冊時間: 06/24/2005 8:55 pm
#1 文章 gary1103 »
just asking if there is any program that i
can set up a mail server and BBS server on Mac system
and is it recommanded? or all i need is buying a PC to have
linux system to do that?
regards
#2 文章 bryanchang »
Mac OS X 已經內建了 postfix mail server 跟 Apache web server,所以你不需要買任何軟體。
ulysses
#3 文章 ulysses »
First you should consider that how much accounts you're going to support. If you just want to build a simple workgroup platform, Mac OS X can handle that well. The system comes with pre-imstalled Postfix, Apache and PHP. You just need to install MySQL to setup a web-based forum with phpBB or punBB.
However, if you're going to open mail accounts for more than hundreds of users, Postfix can handle that too, but you'll need a seperated storage space and different athentication scheme, such as LDAP. In that case, the Mac OS X Server may be the better choice.
For ASCII-based BBS, I've no idea. Maybe you can try installing Firebird BBS on you Mac.
http://ftp.isu.edu.tw/pub/Unix/BBS/Fire ... rebird-25M
