Chinese OS X 10.1 coming next week???
fuigo
文章: 794
來自: 台灣
#1 文章 fuigo »
Dinoking
文章: 21
來自: 台灣/宜蘭縣
#2 文章 Dinoking »
是真的嗎?
今天我打電話去問台灣蘋果一位小姐,她給我的答案是還沒有看到,如有更新的話網站會公佈!
殘念!
Raytse
文章: 18
註冊時間: 10/02/2001 1:01 am
來自: Hong Kong
#3 文章 Raytse »
Actually the chinese version (Tier 2 Language) is out already. I get a new upgrade CD (OSX 10.1) from one of the Apple Shop in HK today and I installed it on top of my existing OSX. It got an option for you to install the additional localization language including traditional Chinese and Simplified Chinese. So try to get a new version of upgrade CD...
[img]images/smiles/icon_eek.gif[/img]
fuigo
文章: 794
來自: 台灣
#4 文章 fuigo »
I just got my copy from a local Apple Retailer... I looked in the "Optional Install" folder, but see now Traditional Chinese Locialization stuff... [img]images/smiles/icon_sad.gif[/img] Guess I'm not lucky enough!
Just have to wait now!
For people who have the "tier-2" version of 10.1, what's the build number??? Obviously, it's not 5G64...
fuigo
oeyvind
文章: 1990
註冊時間: 10/03/2001 1:01 am
來自: 大馬/星洲
#5 文章 oeyvind »
<BLOCKQUOTE><font size="1" face="XYZ">quote:</font><HR>原始發信人 Raytse:
<STRONG>Actually the chinese version (Tier 2 Language) is out already. I get a new upgrade CD (OSX 10.1) from one of the Apple Shop in HK today and I installed it on top of my existing OSX. It got an option for you to install the additional localization language including traditional Chinese and Simplified Chinese. So try to get a new version of upgrade CD...
[img]images/smiles/icon_eek.gif[/img]</STRONG><HR></BLOCKQUOTE>
can you tell us which build is it?
totheend
文章: 92
來自: HONG KONG
#6 文章 totheend »
我的upgrade CD也有中文套件,可選用中文介面和中文輸入,感覺是中英文版合一了。
Upgrade CD版本是5J34
Dinoking
文章: 21
來自: 台灣/宜蘭縣
#7 文章 Dinoking »
為什麼台灣還未看到,我也還沒收到中文昇級光碟!
I'm so angry!
Apple Taiwan!
比香港還不如!
MacAce
文章: 4
來自: 台灣
#8 文章 MacAce »
阿~~原來台灣還沒看到喔?乖乖~~那得感謝蟑螂啦~~我已經裝上去玩了兩三天了說~~感覺上速度沒英文板快(差距不大)~~對了~~我這鍋是直接安裝的版本說~~完整中文界面~~版本為~~ 5L14
Raytse
文章: 18
來自: Hong Kong
#9 文章 Raytse »
My version is 5L14 too
kulong
文章: 62
註冊時間: 05/05/2001 1:01 am
來自: U.S.A./Houston
#10 文章 kulong »
ㄟ?我被搞糊塗了。Tier 2 的 Mac OS X 到底是那個 build ㄚ?我在臺灣的朋友說幫我買到的是 5J26 。
無哩頭
文章: 14
註冊時間: 08/01/2001 1:01 am
來自: 中國
#11 文章 無哩頭 »
From : http://www.imacguru.com/viewtopic.php?topic=373&forum=1
簡單黎講,5J34 係 Tier2,已經有中文輸入法。做左 Software Update 後就會變成 5L14。
而 5L14 唔一定有中文輸入法,要再裝埋個 CLK 先有中文。而餉 24 號之後果隻 upgrade CD 可能已經將 CLK 放埋入去。
即係話 Tier2 玩完,5L14 加上 CLK 係最新既中文 OSX 啦。
[ 10-28-2001: 留言編輯者: 無哩頭 ]
fuigo
文章: 794
來自: 台灣
#12 文章 fuigo »
5L14 is only the build number after doing the Security update. I don't think it has anything to do with tier 2 language kits.
You can find out your "actual" build number in System Profiler. I'm pretty sure it's a different one the number showing in Startup Disk control panel.
My questions is: when can we download the freaking upgrade?
fuigo
overmas1
文章: 68
註冊時間: 06/05/2001 1:01 am
來自: hk
#13 文章 overmas1 »
我安裝了二次
1.只upgrade mac ox 10.03 to 10.1 is 5L34
2.full install upgrade cd ,the version is 5L14
i dont know why!?
oeyvind
文章: 1990
來自: 大馬/星洲
#14 文章 oeyvind »
If you have access to any the 10.1 Tier 2 CD or the full 5L14 CD, you can use the IME_extract.sh here to extract the IME and copy them to your normal Tier 1 OS... and have full IME... [img]images/smiles/icon_smile.gif[/img]
oeyvind
文章: 1990
來自: 大馬/星洲
#15 文章 oeyvind »
Hi Rayse: Can you kindly tell us what's the part number on the package (5G64 is M8621Z/A and part on CD is 1Z691-3184-A), I'm trying to get the Tier 2 CD from Apple here but they have no clue... but say will help me if I can give them a part number.
Thanks in advance!
oeyvind
文章: 1990
來自: 大馬/星洲
#16 文章 oeyvind »
<BLOCKQUOTE><font size="1" face="XYZ">quote:</font><HR>原始發信人 2dn:
<STRONG>我的upgrade CD也有中文套件,可選用中文介面和中文輸入,感覺是中英文版合一了。
Upgrade CD版本是5J34。</STRONG><HR></BLOCKQUOTE>
Package part number? 5G64 == M8621Z/A
Dinoking
文章: 21
來自: 台灣/宜蘭縣
#17 文章 Dinoking »
她媽X!台灣蘋果都是騙子!上星期五我打電話給她們!她們核對好我的資料後說,最慢今天或下個星期一就可以寄給你,請你稍等一下,最慢下星期五前可以收到!﹖﹖﹖﹖﹖
她媽X!真想XXX她們!Apple 迷就是這樣被它(簡直不算人)騙了!讓Steven Jobs總裁把經營權都收回來!總一口徑!有就有!沒有就沒有!不要耍心機!大家自救!救台灣!
真氣人!媽的!
totheend
文章: 92
來自: HONG KONG
#18 文章 totheend »
oeyvind:
5J34 upgrade CD:
Package part number is M8621Z/A,
CD no.:2Z691-3184-A
oeyvind
文章: 1990
來自: 大馬/星洲
#19 文章 oeyvind »
<STRONG>oeyvind:
5J34 upgrade CD:
CD no.:2Z691-3184-A</STRONG><HR></BLOCKQUOTE>
謝謝! One more question, just wondering what's the number beside the bar code, still 18908 38938 (as per 5G64 CD)?
[ 11-09-2001: 留言編輯者: oeyvind ]
kansir
文章: 289
註冊時間: 06/10/2001 1:01 am
來自: 中國㊣香港
#20 文章 kansir »
對不起,我想問一問,中文版 OS X 是否好用?我指看和寫中文是否有問題?
[ 11-09-2001: 留言編輯者: 簡蛇 ]
