Urgent Help! Can't Type Chinese
ziest8
文章: 68
註冊時間: 11/01/2001 1:01 am
來自: Hong Kong
#1 文章 ziest8 »
I'm using OS 10.2. My computer won't respond to my keyboard when I change my input language as Traditional Chinese. It works fine for English, and I can insert Chinese text with display keyboard. Anyone knows why? Thanks in advance!
#2 文章 麻辣杯麵 »
ziest8
文章: 68
來自: Hong Kong
#3 文章 ziest8 »
Thanks but I can't find information related to my problem...
By the way, I don't use Han Yin but Jian Yi.
#4 文章 麻辣杯麵 »
OK, check your setting~
System Preferences > International > Input Menu > Check 繁體中文
ziest8
文章: 68
來自: Hong Kong
#5 文章 ziest8 »
... it's checked
I can't choose to see the option of Trad. Chi., right?
#6 文章 麻辣杯麵 »
Oh, I can't help any more, sorry~
#7 文章 麻辣杯麵 »
Have you installed coreldraw?
ziest8
文章: 68
來自: Hong Kong
#8 文章 ziest8 »
yes
one of the rare days i've been using...
#9 文章 麻辣杯麵 »
That's why!
Cause Coreldraw is incompatible with Chinese input in Mac OS X which greater than 10.1~
If you want to use Chinese input, the only way is deinstall it, or downgrade to 10.1~
ziest8
文章: 68
來自: Hong Kong
#10 文章 ziest8 »
Ok thanks a lot!
